Hi,
Incase anyone wants a quick place to checkout the differences between the various types of attributes you can set on ZFS in terms of deduplication and compression, read on..
root@atom:~# uname -a
SunOS atom 5.11 NexentaOS_134f i86pc i386 i86pc Solaris
root@atom:~#
Note:
1. 0 = Root volume, 1-5 for testing.
Make a number of pools:
1. regular ZFS storage
2. compressed ZFS storage
3. deduplicated ZFS storage
4. compressed and deduplicated ZFS storage (if possible)
root@atom:~# zpool create regular-zfs-pool c3t1d0
root@atom:~# zpool create compressed-zfs-pool c3t2d0
# nice it checks for this, to see if its been created or not
root@atom:~# zpool create deduplicated-zfs-pool c3t2d0
invalid vdev specification
use '-f' to override the following errors:
/dev/dsk/c3t2d0s0 is part of active ZFS pool compressed-zfs-pool. Please see zpool(1M).
root@atom:~# zpool create deduplicated-zfs-pool c3t3d0
root@atom:~# zpool create compressed-and-dedupe-zfs-pool c3t4d0
root@atom:~#
Show filesystems:
Options:
compression=on | off | lzjb | gzip | gzip-N
root@atom:~# zfs set compression=on compressed-zfs-pool
root@atom:~#
Easy enough..
root@atom:~# zfs set dedup=on deduplicated-zfs-pool
root@atom:~#
Also easy enough.
Ok, can it do both?
root@atom:~# zfs set compression=on compressed-and-dedupe-zfs-pool
root@atom:~# zfs set dedup=on compressed-and-dedupe-zfs-pool
root@atom:~#
Wow..
Now for the benchmarks!
=> Also included, time it takes to untar to each one..
root@atom:/regular-zfs-pool# time tar xf /root/linux-2.6.37.tar
real 0m14.199s
user 0m1.381s
sys 0m12.817s
root@atom:/compressed-zfs-pool# time tar xf /root/linux-2.6.37.tar
real 0m16.230s
user 0m1.449s
sys 0m14.762s
root@atom:/deduplicated-zfs-pool# time tar xf /root/linux-2.6.37.tar
real 0m19.161s
user 0m1.519s
sys 0m15.393s
root@atom:/compressed-and-dedupe-zfs-pool# time tar xf /root/linux-2.6.37.tar
real 0m19.636s
user 0m1.548s
sys 0m15.472s
RESULTS:
It appears the dedupe is NOT inline, it runs post-copy:
root@atom:/compressed-and-dedupe-zfs-pool# zpool list
NAME SIZE ALLOC FREE CAP DEDUP HEALTH ALTROOT
compressed-and-dedupe-zfs-pool 139G 223M 139G 0% 1.00x ONLINE -
compressed-zfs-pool 139G 214M 139G 0% 1.00x ONLINE -
deduplicated-zfs-pool 139G 429M 139G 0% 1.00x ONLINE -
regular-zfs-pool 139G 420M 139G 0% 1.00x ONLINE -
syspool 139G 4.46G 135G 3% 1.00x ONLINE -
Notice it is getting smaller allocated for compressed & dedupe as well as
dedupe:
230M->223M (comp+dedupe)
437MB->429MB (dedupe, bigger than the actual data (see regular zfs pool)
# Check some options
root@atom:/compressed-and-dedupe-zfs-pool# zfs get dedup deduplicated-zfs-pool
NAME PROPERTY VALUE SOURCE
deduplicated-zfs-pool dedup on local
root@atom:/compressed-and-dedupe-zfs-pool# zfs get dedup compressed-and-dedupe-zfs-pool
compressed-and-dedupe-zfs-pool dedup on local
root@atom:/compressed-and-dedupe-zfs-pool# zfs get compression compressed-and-dedupe-zfs-pool
compressed-and-dedupe-zfs-pool compression on local
Total sizes:
OK, let's make a copy of the directory on each disk and time it and then check
the space again..
root@atom:~# for i in /regular-zfs-pool /compressed-zfs-pool /deduplicated-zfs-pool /compressed-and-dedupe-zfs-pool
> do
> cd $i
> echo in dir $i; time cp -r linux-2.6.37 linux-2.6.37.copy
> done
in dir /regular-zfs-pool
real 0m26.795s
user 0m0.958s
sys 0m14.747s
in dir /compressed-zfs-pool
real 0m19.094s
user 0m0.883s
sys 0m13.700s
in dir /deduplicated-zfs-pool
real 0m22.661s
user 0m0.859s
sys 0m13.276s
in dir /compressed-and-dedupe-zfs-pool
Wowee! Not quite realtime..
Will wait until these are done and then look at the disk space, but it APPEARS
de-dupe only works on a file/name(?) basis, it did not find ANY files/as
candidates for de-duplication within the kernel source tree (ZERO DE-DUPE),
when I copied the source tree again, then it gets 2.00x de-duplication,
well of course, but I am not going to store many copies of the same data on
the same disk
TOTALS:
This is of course a test scenario, but should give people a good overview
of the differnet ways ZFS can help save space on your disks, I need to test
on some actual/real datasets to see how much it can help in the various pools.
root@atom:~#
Note:
Code:
root@atom:~# format
Searching for disks...done
AVAILABLE DISK SELECTIONS:
0. c3t0d0 <DEFAULT cyl 18238 alt 2 hd 255 sec 63>
/pci@0,0/pci15d9,60a@1f,2/disk@0,0
1. c3t1d0 <DEFAULT cyl 18239 alt 2 hd 255 sec 63>
/pci@0,0/pci15d9,60a@1f,2/disk@1,0
2. c3t2d0 <DEFAULT cyl 18239 alt 2 hd 255 sec 63>
/pci@0,0/pci15d9,60a@1f,2/disk@2,0
3. c3t3d0 <DEFAULT cyl 18239 alt 2 hd 255 sec 63>
/pci@0,0/pci15d9,60a@1f,2/disk@3,0
4. c3t4d0 <DEFAULT cyl 18239 alt 2 hd 255 sec 63>
/pci@0,0/pci15d9,60a@1f,2/disk@4,0
5. c3t5d0 <DEFAULT cyl 18239 alt 2 hd 255 sec 63>
/pci@0,0/pci15d9,60a@1f,2/disk@5,0
Specify disk (enter its number):
root@atom:~#
Code:
root@atom:~# zpool list
compressed-and-dedupe-zfs-pool 139G 124K 139G 0% 1.00x ONLINE -
compressed-zfs-pool 139G 124K 139G 0% 1.00x ONLINE -
deduplicated-zfs-pool 139G 124K 139G 0% 1.00x ONLINE -
regular-zfs-pool 139G 108K 139G 0% 1.00x ONLINE -
syspool 139G 4.06G 135G 2% 1.00x ONLINE -
root@atom:~#
Show filesystems:
Code:
root@atom:~# df -h
Filesystem size used avail capacity Mounted on
syspool/rootfs-nmu-000
137G 1006M 132G 1% /
/devices 0K 0K 0K 0% /devices
/dev 0K 0K 0K 0% /dev
ctfs 0K 0K 0K 0% /system/contract
proc 0K 0K 0K 0% /proc
mnttab 0K 0K 0K 0% /etc/mnttab
swap 3.8G 292K 3.8G 1% /etc/svc/volatile
objfs 0K 0K 0K 0% /system/object
sharefs 0K 0K 0K 0% /etc/dfs/sharetab
/usr/lib/libc/libc_hwcap1.so.1
133G 1006M 132G 1% /lib/libc.so.1
fd 0K 0K 0K 0% /dev/fd
swap 3.8G 4K 3.8G 1% /tmp
swap 3.8G 40K 3.8G 1% /var/run
/dev/dsk/c0t0d0s2 7.6G 136M 7.5G 2% /media/NO NAME
regular-zfs-pool 137G 31K 137G 1% /regular-zfs-pool
compressed-zfs-pool 137G 31K 137G 1% /compressed-zfs-pool
137G 31K 137G 1% /deduplicated-zfs-pool
137G 31K 137G 1% /compressed-and-dedupe-zfs-pool
root@atom:~#
Options:
root@atom:~#
Easy enough..
root@atom:~#
Also easy enough.
Ok, can it do both?
root@atom:~#
Wow..
real 0m14.199s
user 0m1.381s
sys 0m12.817s
real 0m16.230s
user 0m1.449s
sys 0m14.762s
real 0m19.161s
user 0m1.519s
sys 0m15.393s
real 0m19.636s
user 0m1.548s
sys 0m15.472s
RESULTS:
Code:
compressed-and-dedupe-zfs-pool 139G 230M 139G 0% 1.00x ONLINE -
deduplicated-zfs-pool 139G 437M 139G 0% 1.00x ONLINE -
dedupe:
Code:
Total sizes:
Code:
the space again..
> do
> cd $i
> done
real 0m26.795s
user 0m0.958s
sys 0m14.747s
real 0m19.094s
user 0m0.883s
sys 0m13.700s
real 0m22.661s
user 0m0.859s
sys 0m13.276s
Code:
PID USERNAME SIZE RSS STATE PRI NICE TIME CPU PROCESS/NLWP
4336 root 0K 0K sleep 99 -20 0:00:40 11% zpool-compresse/142
4327 root 0K 0K sleep 99 -20 0:00:36 3.5% zpool-deduplica/142
4313 root 0K 0K sleep 99 -20 0:00:23 1.1% zpool-compresse/142
4304 root 0K 0K sleep 99 -20 0:00:13 0.3% zpool-regular-z/142
4508 root 4224K 2764K cpu0 49 0 0:00:00 0.0% prstat/1
the same disk
TOTALS:
Code:
compressed-and-dedupe-zfs-pool 139G 238M 139G 0% 2.00x ONLINE -
compressed-zfs-pool 139G 429M 139G 0% 1.00x ONLINE -
deduplicated-zfs-pool 139G 441M 139G 0% 2.00x ONLINE -
regular-zfs-pool 139G 840M 138G 0% 1.00x ONLINE -
Code:
840M: REGULAR POOL
429M: COMPRESSED POOL
441M: DEDUPLICATED POOL
238M: COMPRESSED AN DEDUPLICATED
