My goal is to build a high performance home server that would be manageable by a newcomer to Unix/Linux. I am not afraid of CLI if part of your recommendation, although using either a built in web interface or napp-it would probably be easiest.
I am trying to decide which O/S to install for my first new ZFS storage system server: I have preferred the following three choices due to the apparent built in compatibility (thru samba) with my other Windows 7 workstations:
NexentaCore Platform3
NexentaStor Community Edition
OpenIndiana
My Server Hardware:
Supermicro X8DT3-F motherboard
-12gig ecc un-buffered Kingston KVR1333D3E9SK3/6G
-Intel Quad Xeon 2ghz E5506 (may add a 2nd cpu later if needed)
-two-320gig (all 7200rpm server grade) drives to be set up for mirrored boot drives connected on the regular sata ports of the motherboard
-five new Sata Hitachi 5K-3000 2TB drives for the primary performance pool attached to the built in LSI 1068E SAS controller
My current data requirements are only 4 TB.
My questions are:
1. Which of these O/Ss would you recommend for a novice and why?
2. Which ZFS raid mode is best for performance?
3. I dont understand how to label the five storage drives so that when the time comes and a drive inevitably becomes defective, I can easily tell which of the data drives needs replacing. Can someone please explain to me how to do this?
Thanks
OpenIndiana
My Server Hardware:
My questions are:
Thanks
