Zalman 9500 Compability
Spherific
A few months ago I bought the
ZALMAN CNPS 9500 AM2
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118004
I want to upgrade to an Intel Q6600 but that heatsink isn't compatible based on the specs.
I'm looking at the regular
ZALMAN CNPS9500
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
It looks like the exact same thing to me based on the specs but it comes with a few extra brackets.
Anyone know if I can just get an extra bracket so it works with Intel motherboards? Thanks.
I would think so. Have you emailed zalman or looked around for the bracket to try?
