matt3lewis
- Dec 25, 2006
hey guys,
this is my first time on the forum. I joined it cause I have one specific question that I'd like you guys to try to answer--a good bud recommended the site to me.
anyway, i just bought the z-5500's. My specs are below:
Asus A8V-E Deluxe
AMD Athlon(tm) 64 4000+ 2400MHz
Windows XP
The sound that comes with it is integrated: 8-channel AC97 codec: Realtek ALC850
So, do you think I should invest in a sound card to go with it. I want great sound from my mp3's. that said, i'm not an audiophile, i just want terrific sound.
If i buy a simple optical conneciton and hook my speakers up to the integrated Realtek AC 97, will the sound be significantly worse than if i were to buy a medium range card (say 30-80$)
What I would like to know most, however, is what cards you would recommend for getting good DTS. Also, what is the cheapest THX certified sound card.
I'd be willing to spend up to 100$ or there abouts.
any info or answers or comments would be greatly appreciated.
Thanks guys
-Matt
Asus A8V-E Deluxe
Windows XP
Thanks guys
-Matt
