YY case owners: simple question
dage
On the yeong yang YY-0221 are the two side doors interchangable? Specifically, can you put the one with the fan cutout on the other side by flipping it around?
thanks!
-mike
No. there are angled hooks on the back that the doors attach to the back of the case with.
they are not interchangeable period... there is also a lip under the door, a rolled lip at the top, and the hooks are off set if you hang them on the wrong side you end up with a 1" gap at the top of the case and the door wont close becuase of the lip
