I want to build a HTPC that can play Blu-rays and record at least 2 HD shows at a time to the HDD. I am using a 60" Sony 1080p Projection HDTV.
Here is what I have come up with so far:
Case: $115 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129034
Hard Drive: $90 http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
Motherboard: $100 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128090
CPU: $57 http://www.newegg.com/Product/Product.aspx?Item=N82E16819103774
RAM: $45 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
Blu-Ray Drive: $140 http://www.newegg.com/Product/Product.aspx?Item=N82E16827106225
Total: ~$576 after shipping
Are all of these parts compatible with each other? Am I missing any parts? Do I need to get a TV Tuner or a Video Card? Will the video quality be full HD?
What operating system should I use? Is there a good Linux OS designed for HTPC?
Do I need any other software?
