I'm trying to decide on exactly what I need to get to upgrade my comp and if I can do it within my budget.
It started out by me realizing that I am a bit short on ram and my vid card could use a bit of a boost and I could also use a dvd burner. Well, if I am doing that much, why not go farther and get a new processor and motherboard and that way I can transfer the old stuff to my second comp.
I have a total of $900 I could spend on this, but I'd really prefer not to spend that much if I don't have to.
I am really lost when it comes to what processor and motherboard to choose. I've tried reading up, but nothing has stood out and so this is where I need the most help. I don't plan on overclocking, however, I suppose I could change my mind later. I have a feeling that the best option for me will be based quite a bit on price. For comparison, I currently run an Athlon64 X2 3800+ and I haven't had any problems with it's performance.
Ram is just as confusing to me, so whatever suggestions of ram that would go with the suggestions for motherbaord and processor would be appreciated. Also, is 2gb ok or should I be looking to get 4? I only have 1gb in my current setup and I am pretty sure it's not enough.
As far as vid card, I think I have decided on an Evga 8800GT. Seems to be the right boost that I need and the price is a bit high, but not outrageous for me.
Dvd burner I could use something besides a Lite On. I have a cd burner by them and my god is it loud. Something quiet and reliable. I read something on these forums about a Pioneer and a Samsung and so I am leaning towards one of those.
Like I said, I plan on using my old parts in my second computer which brings up new issues. The power supply in my second computer won't be able to handle the hand me down parts. This means I would need a new power supply. I have also been thinking about a new case because my current one is huge. So I was thinking about the Antec Sonata III, hoping that it might be quieter and it comes with a 500w ps that I could switch to my second comp.
Then it would seem like a good idea to do something about my crappy little 17" monitor that I use for my second comp. I use a 20" viewsonic on my main comp and I really like it. Would now be a good time to get something like a 22" widescreen or just get another 20"? In either case, which brands and features should I be looking at to make sure I'm getting something decent?
Suggestions are greatly appreciated.
