XS Benchmark V. 0.99 Freeware
bonis62
Hello
this is my Freeware Beta (All Windows O.S. , English and Italian Setup)
anyone help me to test my software on overclocked pc ?
get at http://www.xstreme.it/
Tank
Just wanted to post the virus scan of this file. Sorry its just a little suspicious that your first ever post is to a link to download a benchmark. Looks clean anyway. I'll try it out.
i love you :) :D
the test validation is not necessary because
i use my self internal compression algorithm validation test.
Not possible to create or edit my .dat file out of my software.
Hello
You remember to send .dat generated by the save
after testing in the folder DBench to build
Global online database,
Download the manual Update on site,
V. 0.99.1 in Zip.
Thanks to ...
Following the advice of Darkmaster i performed substantial changes to the modules, for what concerns the internal validation of benchmarks, eliminated all possibility of escape by running test, set tests on graphics, full-screen, and test on windows without the chance to close the same, have greatly improved the ability to detect errors in the test calculation due to overclock too high, await your news, hello:)
Release XS BENCHMARK V 0.99.5
Corrected bugs Xmem
Windows added to the main board
Xsmark corrected bugs
Xbase corrected bugs
Added request to save and upload
Capture window corrected bugs
Updated database Sysinfo
Updated library opengl
Correct several small bugs
Update code thread
Update web site and upload site
www.xstreme.it : Download
nuke.xstreme.it : Upload
