hutchingsp
- Dec 24, 2006
Do any of you push out XP Wireless Network settings via Group Policy?
I'd like to do so, however, the GPO doesn't appear to allow you to specify that the connections you add shouldn't automatically connect.
I'm scratching my head trying to work out if I've missed something as it seems plain dumb that the moment you use a GPO to setup your wireless connection properties, that connection automatically connects even if you're sat at your desk using a cabled connection.
Thanks.
Thanks.
