Xbox/pc case mod
neomage2021
I'm planning on stripping down an xbox and placing it inside a computer case along with my computer. Should be a relatively easy mod. Just modding a blank 5.25 bay cover to house the power switch and controllers. Then lengthening many of the cables on the xbox. I will build a custom mount for the xbox to mount near the pc mobo. I will place the xbox PSU near the PC PSU. and run the xbox av cables to a tv tuner card so that I can play the xbox on my pc monitor. I'm doing this a space saver for college and also because I'm bored and have the extra money to do it now. The xbox mobo is about 9x8 in and the xbox PSU is about 7x3 in.
I was wondering if any of you have a suggestion on a good case to use. I am currently using an old antec file server case, but I want to get something new. It needs to be fairly large.
What are the cases you would suggest for this mod?
*edit spelling
