Just a simple question that I can't seem to find an answer on. Bought a bare x800 XT card and installed it. I hooked up the molex connector but noticed that below it was another 4 pin connector, similar to the type you'd find on a motherboard to plug a fan into. Do I need to plug anything into this; if not, what is it's purpose?
Thanks
Thanks
