Built a dual 5160 on this X7DAE. Am trying to boot up for Windows install.
If I have two DIMMs in it freezes on the POST screen. If I pull out one of the DIMMS (which I thought was unsupported) it flies past the POST and lets me into Setup or will try to Boot Windows.
Windows will start to load (the basic blue screen driver loading) and after 10-40 seconds it will give me a variety of different errors, such as...
File ntkrnlmp.exe could not be loaded.
The error code is 7
Setup cannot continue. Press any key to exit.
Setupdd.sys could not be loaded
The error code is 7
File hal.dll could not be loaded
The error code is 7
I've tried different DIMMs with the same result.
What is going on? Why would two DIMMs fail to work? Is this a power issue? I would think it was bad DIMMs except I've tried 3 different chips.
The error code is 7
The error code is 7
The error code is 7
