anyone get above 2.35ghz with x2 3800+ toledo and 2 gigs of ram on stock cooling... i left the multiplier at 10 and went to 250and i tried to run 05 and it froze up at the very end of gpu test...
well you need to tweak ram settings, maybe your ram isnt able to support 250mhz.
are you running at 1:1 ? what is the ram rated speed, 3200, 4000?
3200 = 400mhz = 200mhz x 2 = 1:1 with the fsb 200 x 10 by default on your 3800. now you raised the fsb to 250, so you overclocked the ram to 250mhz x 2 = 500mhz so maybe it cant run as fast. althought you can run your ram on a divider to make your ram run slower then your FSB, such as 166 or 133 divider. go read the amd overclocking guide stickies
