silentwolf
- Dec 4, 2005
Ok, I jsut went out today and bought a Yamaha home theater system, with a amplifier and 5.1 speakers. I get it home, and hook it up to my Sound blaster X-Fi sound card.
Now here is the problem. I am using the multi channel analog inputs to send the sound from the soundcard, to my amp. However, I cannot get any Bass out of the system. It refuses it use the subwoofer, instead making the speakers attempt to create the lows.
I know I have everything hooked up correctly, because the X-Fi speaker test correctly uses the subwoofer. I have not played any games yet, so I dont know if they will use the subwoofer, but my music applications are not using the subwoofer.
What am I doing wrong? I know its a problem related to the multichannel out, and possibly not all programs using the subwoofer channel, hence being my problem. So basically, I am asking how to get all my programs to access subwoofer channel, or getting my receiver/amp to use the subwoofer in the absence of information on the subwoofer channel.
Thanks for the help.
