X-Box puter....
Hey guys, me again, i saw someone post about an X-Box computer , and i wanted one, so i went out and got an empty X-Box case to put my shit in... All i want to know is how you did it... please make a readme or explain and tell what kind of parts you used (like a shuttle MOBO or w/e) thanks...
its not hard first a mini-itx mobo is the best. and a laptop HDD is the best. and if you want the power supply in it then you have to take the psu out of its case and mount it.
thats all i know but give me a sec i well find a link
why look on google going thro pages on pages when you can ask here hhhhhmmmmmmmm
Damn, I was about to say "cause it's faster", but I can't seem to find anything on the subject either in google.
Open mouth/ insert foot
Try doing a search on this forum then (Google turned up alot of links but it looks like most are crap) and other forums like Bit-Tech.
It's fairly straightforward, put the parts from a pc in the xbox case. Fitting them all together is your part, hence the whole case modding thing. I don't see any real complications - a fairly basic swap.
The ironic thing is that the xbox is probably a more powerfull computer than anything mini-itxish you could put in there. Of course this has it's coolness factor.
mentalmidget=dillon? C-P!
You should show me this x-box puter sometime...you should have told me about it so I could help you with it.
Cause im better than you and everything.....
jus kidding :D
