WU Error - Need some Help
Status
Not open for further replies.
EvilAlchemist
I have gotten a few "Quit 101 - NaN detected: (ener[0])" on my Q6600.
All on project 3060. Will complete 5 WU's ... then error ... then 5-7 WU's ...then error
Does this sound like a Hardware Issue or WU's issue....
Q6600 G0 = 3.0Ghz
Vcore=1.350
DDR2-1.90
MCH=1.350
Linux - Folding CD
F@H Log from Event
[21:59:23] Project: 3060 (Run 4, Clone 21, Gen 25)
[21:59:23]
[21:59:23] Assembly optimizations on if available.
[21:59:23] Entering M.D.
[21:59:23] optimizations on if available.
[21:59:29] ra SSE boost OK.
[21:59:29]
[21:59:29] Extra SSE boost OK.
[21:59:29] Writing local files
[21:59:29] Completed 0 out of 20000000 steps (0 percent)
[22:11:45] Writing local files
[22:11:45] Completed 200000 out of 20000000 steps (1 percent)
[22:24:14] Writing local files
[22:24:14] Completed 400000 out of 20000000 steps (2 percent)
[22:36:41] Writing local files
[22:36:41] Completed 600000 out of 20000000 steps (3 percent)
[22:48:38] Writing local files
[22:48:38] Completed 800000 out of 20000000 steps (4 percent)
[23:00:33] Writing local files
[23:00:33] Completed 1000000 out of 20000000 steps (5 percent)
[23:12:47] Writing local files
[23:12:47] Completed 1200000 out of 20000000 steps (6 percent)
[23:25:12] Writing local files
[23:25:12] Completed 1400000 out of 20000000 steps (7 percent)
[23:25:50] Quit 101 - NaN detected: (ener[0])
[23:25:50]
[23:25:50] Simulation instability has been encountered. The run has entered a
[23:25:50] state from which no further progress can be made.
[23:25:50] This may be the correct result of the simulation, however if you
[23:25:50] often see other project units terminating early like this
[23:25:50] too, you may wish to check the stability of your computer (issues
[23:25:50] such as high temperature, overclocking, etc.).
[23:25:50] Going to send back what have done.
[23:25:50] logfile size: 137789
[23:25:50] - Writing 138338 bytes of core data to disk...
[23:25:50] ... Done.
[23:25:50]
[23:25:50] Folding@home Core Shutdown: EARLY_UNIT_END
[23:25:54] CoreStatus = 72 (114)
[23:25:54] Sending work to server
I've personally had exactly 0 of those in 6 months of running SMP, so I can't tell you one way or another if it's a generally bad WU. What I can tell you is that from experience, the NaN error for me has been bad WUs. Hardware related errors are usually floating point imprecision for me.
I just now checked the bios and I had "EIST" @ C1E still enabled.
Been reading that is can cause some stability issues ... causes some vdroop
I disabled both.
I am hoping someone else has had this happen ... i am baffled....
I wanna think it is WU related due to the fact that the system can complete so many WU's in a row ... and complete many more afterward ....
When I have gotten an error on the Fold CD it told me it was hardware. Mostly from me pushing that poor 2160 too too far :p
I disabled both.
No need to be baffled on an early end. We used to get a lot more then we are seeing now. As a rule it’s not a hardware issue and Stanford has acknowledged they happen from time to time and sometimes it is actually the result they expected/wanted.
3060’s are really chewy and do put extra stress on the CPU, make sure your temps are in range and double check the vcore; you might have to go up a notch.
At least you were only at 7%, it stings like hell when you see one at 99%;)
Status
