I am looking for a simple PCIe sound card, prefer that it has optical out as well as with the regular 5.1 sockets.
Stuff I have to trade
Galaxy S3 phone
1 x 120 rad
2 x 120 rad
GTX 560
PCIE sleeved extenders, x6 and x8
Motherboard power sleeved extender
Gigabyte GA P35 DS3L motherboard
Intel Core Due 4620
Memory for the P35
pics available on request
No problem. This is a vintage 7.1 card, one of the very first if not the first 7.1 card ever made. Sounds great. I can throw in an optical cable if you need one.Hello all, thanks for the reply. I have posted a pic of my motherboard above (119594_dell-pci-slots.png) so you can see the availble slots.
joe7dust thank you for posting the pics.
@vivo & dook43 could you post pics of your sound cards?
I'm posting pics of memory available. They are all 2 Gig sticks.
Wow really? I didn't know that is how it works. I currently use HDMI from my GTX 1060 then optical out from the TV for audio to my sound system. So if I got the cheapest usb or pcie to optical card out there I would get the same or better quality?If you need optical out, it doesn't really matter which card you use because you'll bypass the cards processing and process at the destination. Is it that your motherboard doesn't have the outputs? I would go with a cheap USB solution. I might still have a Xonar U3. I have to check, but I will let you know
Still looking? Still have mine, which should be compatible with both types of slot, have only used it in the configuration using the adapter.Pending deal fell through. Still looking for sound card. I posted pic of slot it needs to go in. https://hardforum.com/data/attachment-files/2018/04/119594_dell-pci-slots.png
Out of curiosity, how many?Still looking.
I could use 8 bay covers. Also, I could use the cover that has a cutout for 3 1/2 external device, like a floppy drive for example.Out of curiosity, how many?
8? Jesus, the thing only has 9 bays. the 830 model?I could use 8 bay covers. Also, I could use the cover that has a cutout for 3 1/2 external device, like a floppy drive for example.
Hey, how ya doin? I just moved offices and the stacker is still in storage, but when back in service will perform file storage. They don't make them like they used to.How's the stacker?
Nope they sure don't!They don't make them like they used to.
