I have the following chip that I would like to trade for a S370 P3 1GHz CPU w/SL4MF s-code.(this is what I'm looking for!) I can only accpet this s-code as this is for a dually set-up.
Intel Pentium 2 1.133GHz (this is what I have)
1133/256/133/1.475
SL5GQ s-code.
I believe that this chip is a tualatin core. I do have an adapter that comes with it that was on the motherboard when I bought it. I believe that the adapter is to adapt the tualatin core to a normal S370 motherboard. The only catch is that the small tab on the adapater that holds the CPU on has a crack in it. It is not broken all the way off but there it is fractured. The tab fractured last nite but there is still enough to attach the HS to. I was able to power this up with the adapter on my Asus CUV4X and it was recognized as a 1133MHz P3.
Pics available upon request.
Thanks,
mike
1133/256/133/1.475
SL5GQ s-code.
Thanks,
mike
