xX_Jack_Carver_Xx said:We were having this, turned out to be the "wireless zero config" service in windows. On a recent MSoft update something changed in how it worked, and it would "do us a favor" out trying to find a BETTER connection....hang....no find one.... reconnect. In the meantime you see it aws dropouts and disconnects.
I turned OFF the WZC service and forced windows to use my adapter utility for configuration rather than letting Windows do it. So with DLink/Belkin/etc adapters and the WRT54GS all is now well, been flawless since.
wahoyaho said:i upgraded to latest firmware and it woked for me
turn off upnp if u use azereus
Sloth_Boy said:The XP utility is the wireless zero config utitlity. Tell your roomate not to use it and you should not get anymore disconnects
Stang Man said:i might just do that... can i do that even though i bought it back in like May?
Stang Man said:what's he supposed to use then?
ktwebb said:You use the WZC utility. You only need that to connect. Create a batch file on your desktop to stop the service AFTER you've connected, got your IP etc...
Open notepad. Type net stop WZCSVC
Save it as "all files" in the drop down box and call it whatever you want.bat ex wireless.bat
Once you've logged into windows just double click the batch file. You can also create one to start it. net start WZCSVC
If your card has a utility for your card and works in XP, some don't because WZC exists, then you can just disable it all together if the vendor utility works well for you.
Stang Man said:thanks but no thanks. WZC works perfectly fine on every router except the linksys. this has happened on 2 different linksys routers now. Connecting to a cisco aironet ap or netgear never has this problem
the linksys routers are just pieces of shit and i'm just going to go out and get something else
IceWind said:
Stang Man said:if Linksys and WZC doesn't work together, then just say it.
ktwebb said:Well, he rolled his eyes because Linksys doesn't work with WZC is a ridiculous statement. Worthy of an eye roll to those who know, of course linksys works with WZC.
Stang Man said:how come it doesn't work now... that and my laptop is running Slackware 10.2, so there is no wireless zero configuration to begin with![]()
