The upgrade itch has been nagging me for quite a while now, and since I haven't come across any reasonable hardware upgrades, I have money to spend elsewhere.
I currently have a Hardware Labs 360 GTX and 120 GTS. I have considered replacing the 360 with either:
- The Hardware Labs 560 SR-1 sporting 4x140mm fans and 9 FPI.
- The Hardware Labs 560 GTX, 4x140mm fans and 20 FPI.
- The Magicool 540, which supports 3x180 mm fans with 13 FPI. Mind that this radiator is only 35 mm instead of the 54 mm of the HWLabs radiators.
Since I am using the FT02, I currently have five 1850rpm Gentle Typhoons on my 360, so almost push pull
The question is this: Do you think it's worth it getting one of the above radiators? If so, which do you recon have the best performance increase? Or do you think it's a waste? Please chip in.
Personally I like the looks of the Magicool, but if it no better than my current setup, I won't consider it.
