World’s First Android-Powered Netbook Priced
Terry Olaes
I Used to be the [H] News Guy
The Chinese maker of the Alpha 680 netbook that will run Google’s Android mobile OS told ComputerWorld that final testing is in progress and the price will be around $250. The netbook will also be using an ARM chip, which is normally used in mobile phones, and are cheaper and more energy-efficient than Intel’s Atom CPU.
The Alpha 680 will have a 7-inch LCD screen at 800 x 480 pixels, 128 MB of DDR2 RAM (expandable to 256 MB, a 1 GB solid-state disk drive (expandable to 4 GB), though users can also add storage through the SD card or two USB ports. It will also have built-in Wi-Fi, keyboard and touchpad.
UNless the price falls really fast I predict a flop. Entry level atom netbooks can be found for $200ish and both the MS and *nix ones have far larger selections of apps.
You'd be better off carrying around a smart phone.
And only two to four hours of battery life? Forget it.
From SD front page:
Dell SB has Vostro A90 (similar to Dell Inspiron Mini 9) for $199 + $8 S/H = $207. Thanks pogiboi
Specs
Intel Atom Single Core Processor N270 (1.6GHz/533Mhz FSB/512K cache)
512MB DDR2 at 533MHz
8GB Solid State Drive
8.9" Wide Screen WSVGA TL Display (1024x600)
Integrated 0.3M Pixel Webcam
Intel Graphics Media Accelerator (GMA) 950
Wireless 802.11g Mini Card
Bluetooth 2.1
32WHr Battery (4 cell)
Ubuntu Linux version 8.0.4
1Yr Ltd Warranty and Mail-In Service
And I hear its 4 hour battery life.
I fail to see how this $250 is any better
Androide runs Linux.
Linux supports ARM.
This wont limit it.
What will limit it, is disk space and memory!, DDR2 1gb cost almost zero, i agree, flop for this laptop.
Androide still have a shot though.
so its an oversized mobile phone, without the phone capabilities, for $250?
meh..... *pass*
From the article: The Alpha 680's 2-cell battery will last between two and four hours while surfing the Web using its built-in Wi-Fi or optional 3G antenna, Wu said. That is far less than the eight- to 12-hour battery life that ARM has talked up.
Looks like it can support mobile internet.
It doesn't say whether this supports touchscreen though. The article mentions the 700 model having touchscreen capabilities, but due to cost restraints, the features are not included, and requires you to use a stylus.
$200 netbook. (Aspire One on sale, Dell Mini on sale, etc) 9 hour battery on eBay. Total cost: About $265 and with full x86 capabilities... and a bigger screen, larger storage and more ram.
Yeah. Get this thing down to $100 and we'll talk.
Even if many Linux apps are available for ARM, being able to run x86 code is a huge advantage for the Atom. Also the Atom isn't a bad CPU at all, it's pretty snappy for basic office use and web browsing. Anything ARM tends to be sluggish and laggy during use.
I told you so. A little while back ago I said Android netbooks were already in testing, and there were a couple of skeptics.
