Asus z97-a
I5-4670k
Corsair RM850W Power Supply
ADATA XPG V1.0 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600W8G9-RB
It all started with
Event Viewer is "Level = Critical, Source = Kernel-Power, Event ID = 41
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
which I assume is related to
Event 55, Kernel processor power
Processor 1 in group 0 exposes the following power management capabilities:
Idle state type: ACPI Idle (C) States (1 state(s))
Performance state type: ACPI Performance (P) / Throttle (T) States
Nominal Frequency (MHz): 3401
Maximum performance percentage: 100
Minimum performance percentage: 23
Minimum throttle percentage: 23
I googled it. Tried a bunch of things. None worked. Fast forward.
I reset my bios
power comes on, fans whirl
Post failed
Cleared CMOS
Post failed
Removed all but 1 stick of memory
POST!
if I try to use dual channel i.e. slot 1+3 or 2+4
Post Failed
If I use 1+2 or 3+4
POST!
I have tried a bunch of things like
6 hours of memtest
re-seating the CPU
but I have finally hit a wall.
Please advise
EDIT1
I have also been monitoring voltages and they have been steady
I5-4670k
It all started with
I reset my bios
Post failed
Cleared CMOS
Post failed
POST!
Post Failed
If I use 1+2 or 3+4
POST!
6 hours of memtest
re-seating the CPU
Please advise
EDIT1
