Stupid_Newbie
- Dec 4, 2005
Well my 2500k won't manually oc. It will oc genie to 4.2, but if I set the same settings it posts but hangs ole fore windows load screen. I have been on the msi forums, tried multiple bios, and know working settings. No go.
Tried turbo oc. Set turbo to 48, to see what happens, it only ramps to 34. They suggested pulling CPU and checking for bent pins. All looks good. CPU stayed stuck to my d-14, should I reseat it? There is no more retention bracket on mobo, as the d-14 removes it for their bracket.
What do you think?
Sorry tough to take pics with iPhone.
Also no temp issues even at 4.2 oc genie.
Could raise multi with control center to 49 till it locked up. But that's on the fly so I know it will run at 48, as I had ibt and prime priority 10 torture running
Also have tried going down to 8gb (currently running 8gb) and no change. Auto also wants to pump 1.75 to my ram.
What do you think?
