liquidfluidity
- Dec 28, 2006
In the settings, there is a spot in which you can set the range of IPs to assign to connected computers and other devices. This particular option is available under the "LAN" options. What I am seeing is that the only IP that is assigned within the range is the one and only device hardwired to the router. Everything else is being assigned IP addresses outside of the range. Am I missing something? I was under the assumption that any IP addresses assigned dynamically would be within the range whether they were wired or wireless ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
