Hey all,
I will be getting a new rig really soon, and it will be top-top notch.
Im talkin 1 gig matched cosair LL w/ the LED lights, and maybe a X800XT PE (Ill probly end up getting just the XT not the PE, but who knows) I would like to know witch cpu is best now, in both price and value
I am looking at the 3.4 Ghz or the 3.2EE or maybe even an athlon 64. fx-51 or 53, or maybe a 64 3200+ or 3400+ or 3700+ . I really dont have a clue about the exact performance ratings of these chips.
I would like to know whats the scoop on the northwood and prescott chips? I have heard that the northwoods perform marginally better and run a bit cooler? Is that true? Witch is better overall? Prescott or Northwood? I would be interested in extreme OC'ing with the best air cooling thats under $50, and I will be purchasing a good mobo and good ram and GPU, so I need some opinions, on witch chip is right for me. I am leaning more into the P4's over the Athlon 64's because they OC higher and run cooler? I wont be offended when ppl correct me because I admitadly, dont know alot. Since the northwood and prescott chips cost about the same, witch should I get? There doesnt seem to be any current advantage of the .9 nanometre prescott ... if anything, it would seem to be slower and run hotter..... will this change in the near future ? Also, What is a safe bet for Athlon 64's ? I would specifically like to know what makes a clawhammer 64 better then a newcastle 64? they run 200 Mhz slower but have half the lvl 2 cache ? What difference in real world gaming and computing does this difference have? Witch is easier to OC ?
And finally, what order of "good-ness" are these chips in --> P4 3.2EE, P4 3.4C and 3.4E , Athlon FX-51/53, Athlon 64 3200+/3400+/3700+ Clawhammer and newcastle for each. What does the FX-51 compare to in P4 Terms and to other athlon 64's, say a 3700+ clawhammer ?????????????????????????????? Also, could you please recommend any good mobo/cpu/cpu fan/sink combos for the chips you talk about...
Thanks alot guys, your great.
Evan
Evan
