Hope someone can give some advice... I am trying to setup a wireless network at my church and was hoping someone could suggest how to set it up. There are two buildings, the chapel and the rectory. The cable modem is in the rectory and I need to connect it to the chapel. If I were to run cat 5, the route would be about 360ft
The limit for cat5 is 328ft
Fiber is too expensive!!! So wireless seems to be the way to go
especially since neither building is wired for cat5. Now the line of site distance between the two buildings is about 175ft.
If I were to get the Netgear WGT624 http://www.netgear.com/products/prod_details.asp?prodID=214&view=
And add on a higher gain antenna like the ANT24D18 18 dBi Patch Panel Directional Antenna or the ANT24O5 5 dBi Omni-directional Antenna. Would this service the entire area?
The chapel has a garden level basement that is facing the rectory. In the chapel, there is an office and classrooms in the basement and one office on the main level. In the rectory, there is an office in the basement. I would like to setup the network so that there is coverage on both levels of both buildings.
I have seen some wireless systems that have repeaters but the wgt624 does not. Do you thing the wgt624 would service the entire site with the 5dbi antenna? How/what would you recommend?
Thx,
Rod
Thx,
Rod
