Hello,
I recently setup a wireless network, with a Linksys B router / access point in place. There are 5 machines connecting to this network. 3 laptops ( all 3 work and get good reception) and 2 Desktops. One desktop will connect just fine, however a second can see the network (using the zero configuration util) but will not join. I can see the SSID, and click connect, but then it just resets. I think the signal maybe weak in that spot, becuase it is in a corner under a desk. I put one of the laptops down there. It did not lose it signal, but it was EXTREMELY weak. Asides from buying an better antenna (which i have done), any other suggestions? Thanks!
-Roast![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
-Roast
