Wireless music transfer?
mdude85
Hello all,
I'm looking for a device which transfers audio wirelessly from my computer to a home stereo system. I don't need or want any fancy screens or advanced controls. I just want a box with an input from my computer, which transmits audio wirelessly to a receiver with an output to my stereo. Every sound that comes out of my computer I just want to play through my stereo speakers, but I just don't feel like running an audio out cable across the floor of my room. Any ideas? Looking for something cheap (less than $100). Are there any add-ons for existing wireless routers that might do this also?
Thanks,
Scott
Out of your pricerange, but i'd highly recommend the squeezebox from slim devices. Does exactly what you want, and is about $300.
If you room isn't too huge then just run a cable across the baseboards... It'll do what you want and be far cheaper. You may want to invest in a good quality cable to minimize signal loss over a long cable run, but you don't need to spend more than $50 on this option.
