DigitalMP said:The signal is excellent, and the network key was accepted, but I can't seem to get an IP address, or ping the router.
Any suggestions?
The ethernet PC on this router (Linksys 4 port w 802.11b) is accessing the www with no issues.
Any suggestions?
QwertyJuan said:Perhaps pinging is disabled in the router?? DHCP could also be disabled which COULD be the other half of your problem.
QJ
P.S. I love you ktwebb....
Forget DHCP, set your IP statically and make sure it works. Then you *know* the wireless stuff is correct. Once you get that working, getting DHCP to work should be easy.
DigitalMP said:Linksys support sucked, but tomorrow morning I'm going to try and set it up without encryption. It's a 3 PC p2p, and they each have firewalls installed, so I should be ok without it, right?
It doesn't matter, because unless they are parked in your driveway they won't stand a prayer of sniffing anything, and even then it's doubtful, depending on the WAP and environmental factors.Malk-a-mite said:Encryption is to protect your data in transit, not to protect your PC. Think about your passwords, usernames, account numbers, and everything else you do online being available for anyone with a wireless card and a sniffer.
