wire sleeves??
Cleaner, easier and neater if you remove the connectors. It's easy with the tools.
Here are a few kits that have new connectors and the tools along with the sleeving, or the tools alone.
Yes, to make it look nice you will need to remove the molex connectors.
Dont forget heat shrink for the ends.
I had a good article somewhere that goes through it step by step.....just google PSU sleeving, there are a bunch of good guides.
Buy the $10 molex tool from FrozenCpu.com, or a sleeving tool set so you can work on the Floppy,SATA and 24 pin connectors,too. Small jewelers screw drivers work well too.
It takes a day to do it right, but looks sweet when its all done.
Good sites for supplies......FrozenCpu and performance-pcs.
Yeah, removing the connectors is your best bet. You can get a molex removal tool from most case modding websites for < $10.
thanks people . i figured i had to remove the connectors . i just wanted reassurance .
i bet it does look neat . i saw some pics here on this thread of how they look .
i think its worth a days work to get a case to look nice and clean on the inside .
thanks for the replies and links .
much apprecitated .
cheers .
