To anyone that has had luck with WinXP64...
I downloaded MS's 6-month trial of WinXP64 and installed it on a second partition of my SATA RAID array, using Via RAID drivers for WinXP64.
All installation went fine, all files copied over to partition, and the WinXP64 bootscreen loads. However, instead of going into desktop or logon screen, after the bootscreen it flashes for a split second with a BSOD and restarts the comp... Very frustrating.
Anyone have an idea how to possibly fix this? It seemed to install fine but now does not want to get into windows itself... Hardware issues?
