thenixhex311
- Apr 30, 2005
Ok. here are the specs first
amd 3700 san diego / xp90
1gig corsair VS ram
msi k8n neo 4 platinum mobo
leadtek 7800gtx
nec 3200AG dvd-rw
maxtor diamondmax 10 200gig SATA 16/mb
Ive built computers before (this one im using) and never had this problem.
the mobo/bios recognizes the Maxtor drive right away, I have it hooked up to SATA 1 (never had 8 sata slots in a mobo before...i AM going to add 1 more sata and 1 IDE to this system)
anyways, I disabled raid, computer recognizes it fine, and when i boot from my XP cd, it goes through all the "loading blah blah blah" but then when it comes to the screen where it says "START WINDOWS INSTALLATION" or whatever that shit it does say...It HANGS.
No screen comes up asking me to format the hard drive. Nothing
I tried to install this drive in SATA 1 on this system with my current SATA drive and OS on SATA 0 and it wont boot. I wanted to format it that way, in windows, thinking that might be the problem. I already tried installing it as the main drive in my old system, but the motherboard/bios (Gigabyte 865pe chipset) will only format it as 131gig or so, losing the other 60+gigs.
WTF is going on here?
Can someone PLEASE HELP!!?!
1gig corsair VS ram
leadtek 7800gtx
nec 3200AG dvd-rw
