I recently setup at winodws 2003 server and am trying to connect it to my home network.
The workgroup name is BASEMENT and i have that properly configured however when I go to connect to the work group i get the following error: You don not have access to the resource. contact sys. admin.
windows was not able to find the list of servers for the workgroup.
In network places i can see the workgroup but i cannont access it.
This is a fresh install. besids adding an additional admin. account and turing on the windows firewall I have done nothing else to the system.
I have ran windows update on this machine and also get an error w/ vssapi.dll, but i dotn think that is causing this.
The other machines on the network, a xp pro and xp home can both see each other and can see the server in the workgroup but cannot connect to it.
The xp pro machine is currently running ics w/ its own firewalls. yes i have tried this w/o the firewall however it still didnt work. Im looking to replace the xp pro maching w/ 2003 to use as a file server.
Any insight as to why windows networking is not working on 2003?
also does anyone know if i reinstall windows 2003 on the same machine(if i can't find a fix to the vssapi.dll prob) if that will mess up the product activation?
Thanks
Thanks
