www.performance-pcs.com
u have to send them ur panel though and they mod it for u ..
u can either get just a window .. or a window with 2x120s in it
not likely unless u make one urself
I saw some somewhere, but you're right that the normal case comes with mesh so I guess it was a modWhere do you find the nvidia edition with window side panels?
As far as I know, they come with light green mesh side panels.
wish CM would release a windowed panel
me too! that was the deciding factor foe me, so I got an Armor instead. The Nvidia 830 with the green looks freakin sweet though,,,,but ya, an 830 with a window would be l33t!
Man there is no way I'd take an Armor case even for free. Those useless flaps on the front are a deal breaker for me.
