Well, this is shocking . I discovered this by accident, because a scanner wasn't working.
The problem is that the scanner services don't work. How did I find out? Cause I can't enter to ANY service:
- Users and machines in active directory and all the administrative tools under the control panel (performance, services, license, etc etc etc. I translated these from spanish so be patient with the lousy translations guys !)
- Radmin and VNC don't work on this PC either... they work as services.
On VNC I get an "the key is not valid" when trying to connect, when I try to change it, I get an error that I interpret as a service that was not loaded.
Anyway, I don't know if this problem of not being able to configure the admin tools is the same that is causing some services not to load correctly, but I believe they are; they started at the same time.
Any ideas? I'm clueless !!!!
