Not to sure how many of you here are familiar with the suspension system on a 3000GT VR4 so i will explain it in a nutshell.
the ECS will adjust all four shocks individualy from soft to medium to hard depending on how the car is driven, and how brakes are applied.
My idea is to make indecator lights for the 3 different settings using a tri color led, red, blue, green
Green=soft
Blue=Medium
Red=Hard
If i am reading my maintainence manual correct the way the struts adjust is this
constant 9V = Soft
9V + 5V = Medium
9V + 5V + 5V = Hard
Will the following curcuit work for this, if you need more infon on anything let me know
Link to the NEC IC
Green=soft
Blue=Medium
Red=Hard
constant 9V = Soft
9V + 5V = Medium
9V + 5V + 5V = Hard
Link to the NEC IC
