Will this case provide good cooling?
sculelos
http://www.newegg.com/Product/Product.asp?Item=N82E16811129159
Thats an antec case with a 480Watt power supply, I'm going to put this stuff in it.
X2 - 4200+ (for 11x Mult)
2GB Gskill value ram (don't care about ram timings much)
Video card, eather 7900GTX or X1900XT(X)
Epox or Asus Mobo
320GB Western Digital Hard Drive
Lite-On DVD-RW
So will it cool adequetly, I'm planing to overclock the cpu to 2.4Ghz or maby more, and don't want anything going crazy on me.
Definitely, but you might wanna install some quiet 80mm fans in the front to balance the airflow out a little bit.
Eh, good idea, I have like 8 fans 80mm fans in a box, I wander how many I could fit in the case?
jcll2002 said:
cram in as many as you can lol ;)
Eh, I though you said you where going to stop posting in this thread :p
Anyways, I'll probably be able to fit in 6 in there, should get some nice airflow going, I really want to order my parts now but I will stick to my plan of waiting till the 7900GTX is reviewed so I don't order the wrong motherboard, depending if I want sli or crossfire.
