I find myself somewhat unexpectedly looking into some possibilities for a modest-sized church environment as well as perhaps my home environment for wifi coverage.
Neither environment has a 24/7 server at this time. I am not an expert in enterprise-grade, controller operated wifi networks at this time.
Off the top of my head some requirements:
I've heard some conflicting info about the role the UniFi controller plays and may require clarification. Is it required to be constantly operating for node-to-node roaming and hand off or is it only required for initial config (assuming no hotspot)?
Is Ubiquiti still a decent value option? Neither home or the church have a large IT budget.
What is the latest state of the art in UniFi alternatives to a server or VM? Raspberry Pi? OpenWRT? Other Intel Atom micro-linux? I've read a bit about Amazon AWS (not sure if I can use it from Canada).
- 802.11n (no need for ac)
- dual-band is a nice to have
- support for multiple SSIDs with different VLANs ("internal" net for staff, visitor net for other parishioners
- Possible hotspot-like functionality for the church - may just need to display AUP and log acceptance of terms for each client. No authentication
- Intelligent multi-node functionality and handoff between nodes
- I want it to "just work" with a wide range of devices and even when signal strength is less than ideal
- interference from other systems isn't expected to be a major issue
- an ability to QoS-shape/prioritize internal vs. public traffic is a nice to have
