Direwolf20
- Mar 10, 2004
Ok, this is definately a wierd issue, and Hopefully you guys can help me out with what might be the problem here....
First, the system:
I have a P4 3.2ghz processor, ati Radeon X700 256MB video card, 1g DDR ram. I have a 300 watt power supply, which according to the Radeon X700 box is the minimum.
I know my way around the inside of the computer pretty well, but I'm not really a hardware expert, I reside more in the software realm
Now, the problem:
Sometimes if I turn off my computer, and open the case to do something, when I put the case back on and turn on the computer, the video won't initialize...I can hear the system booting up, and I'm pretty sure its going into Windows (because once i DO get it working, it says windows didn't finish booting last time, yada yada). Theres just NO video.
It seems to me at that having the computer on its side would give it a better chance at booting properly, but usually when I would stand it upright the video would freeze. For example, several times I laid it on the side, and turned it on, video showed up and all was well. I let it boot into windows, all is fine. I stand the PC up, and then I move the mouse, where the mouse cursor used to be is now a box of wierd colored dots, and the whole thing is frozen up.
I'm positive the video card is securely in the system. Its not loose in any way shape or form.
Also, it seems if I unplug the monitor from the back of the case for a few seconds, then plug it back in, I have a better chance at getting it to boot properly.
After several tries, I usually get it working from a standing position, and then I just leave it on. Once its working, it works FINE. No problems, runs beautifully, and as long as I don't shut it down I don't have ANY problems.
So, pretty wierd huh? Any advice? Anything I can check? I'm totally confused ;(.
First, the system:
Now, the problem:
