Super KW said:hi
i just got my new silverstone 750w with quad 12v 18a each (60A combined) and i see in the bios reading is 11.84 and 11.78 ?? is that normal ?
amd ati FO SHO said:Software/bios reads can be off.
Do you have a multimeter to test?
mine say 11.8x and mm tests 12.0x
But those numbers look about right
mikeblas said:Multimeters can be off, too.
I've seen DC accuracies which are less than the specs for the monitor chips. $20 specials from Home Depot and Radio Shack, for instance.chinesepiratefood said:they are far more accurate than any software readings though
ValeX said:Where DO you stick the ends of the multimeter anyways? I've never done it...
ValeX
We can only wish that this was true in all cases.chinesepiratefood said:they are far more accurate than any software readings though
It certainly can be THAT OFF; check the specifications yourself. You don't know if it's THAT OFF or not. It might be THAT OFF today, and not THAT OFF tomorrow. That is the nature of error and tolerance.jonnyGURU said:I don't think it would be THAT OFF even with a $20 Radio Shack DMM, but you do make a very valid point.
fireburster said:mines at 11.54 in bios and in mm. Thats not good right? Its fsp 530w.
I think that the $3 ones are off by just 1-2% when measuring DC voltages.mikeblas said:Multimeters can be off, too.
Where can you get a multimeter for $3?larrymoencurly said:I think that the $3 ones are off by just 1-2% when measuring DC voltages.
The ATX Spec says that there's a +/- 5% tolerance for the +12-volt line. So anything between 11.40 and 12.60 is acceptable.fireburster said:mm= multi meter in my case. 11.54 is low though right? i opened the case and turned up the 5v pot and my 12v is reading 12.5v with a multi and in bios.
mikeblas said:Where can you get a multimeter for $3?
Applications where 20% error is tolerable are rare indeed, and for me don't include automotive troubleshooting. If my fuel pump is getting 10 volts instead of 12, I'm not going to win many races. There are many meters which have decent accuracy which aren't "insanely expensive".bob said:Harbor freight. I bought an armload of them, because I end up dropping mine/loosing them. So when I drop one/lose it, im only out $3.00.
They arnt all that accurate if your trying to do real crap, but if your just poking around saying "yep, ive got about 12v here and 10v there and...", they work fine. Ive compared them to the insanley expensive handheld fluke unit my school had, it was "close enough".
mikeblas said:There are many meters which have decent accuracy which aren't "insanely expensive".
mikeblas said:Applications where 20% error is tolerable are rare indeed, and for me don't include automotive troubleshooting. If my fuel pump is getting 10 volts instead of 12, I'm not going to win many races. There are many meters which have decent accuracy which aren't "insanely expensive".
In your post, where you're comparing a measurement of 12v to a measurement of 10v.bob said:Where do you see that the multimeters have a 20% tolerance?
mikeblas said:I'm not sure why you can't find them yourself, but I guess I can give it a shot when I have time. What's your definition of "not insanely expensive"? What minimal functions are you looking for? Which features are required? Which form factor?
mikeblas said:In your post, where you're comparing a measurement of 12v to a measurement of 10v.
mikeblas said:I don't see any $3 meters at Harbor Freight; this one is cheapest, and it's $10.
Its good enough to check "We have about ____ volts here, we dont have voltage there", which Is what I was trying to get at. 1.5% of 12v is 0.18v, which may not seem like much, but 12v could read anywhere from 11.82 to 12.18 volts. And its fairly trivial, considering its near what the voltage tolerance of some PSUs are (around 1% for decent ones). Just 4/100ths of a volt off from some PSU's specification. 4/100ths of a volt could be caused by a drop in voltage across the power leads on the ATX PSU, phasing of the moon etc.mikeblas said:Its manual specifies an 0.5% basic accuracy for VDC, which isn't bad for the price—but still probably not good enough for testing PC power supplies. Note that the meter has a 0.5% accuracy for its 2V range, but a 1.5% accuracy for all other ranges -- including the 20V range which you'd need to measure the 12V output of your supply.
mikeblas said:In this range, the meter has a resolution of only 10 mV, which means your reading of 12V carries an inherent inaccuracy of more than 0.8%. This is the problem with most super-cheap meters; they're only 3-1/2 digts, and that reduces their resolution for useful measurements.
Sure, for packing into your bump-around toolbox, this kind of meter is better than nothing. But I don't think it's too useful for anything else.
Then my meter must have been reading the 100% too high in the case of the +12V rail of my ECS K7VTA3 v. 8, but I doubt it because the hard drive was spinning. Even MBM5 was off, but only by about 12%.techie81 said:It's from speedfan so it can't be off by that much.
I'm looking at the math the other way. If I have a meter with 1.5% tolerance, and I'm trying to test a power supply to see if it is within ATX spec or not, I'm going to have to throw out a lot of power supplies that are marginal, but good. A supply with 11.40 is still just within the +/- 5% specified tolerance, for example. But I have to see 11.57 volts on my meter, which might be reading 1.5% low, to be sure.bob said:Its good enough to check "We have about ____ volts here, we dont have voltage there", which Is what I was trying to get at. 1.5% of 12v is 0.18v, which may not seem like much, but 12v could read anywhere from 11.82 to 12.18 volts. And its fairly trivial, considering its near what the voltage tolerance of some PSUs are (around 1% for decent ones).
SamuraiBlack said:Something that will give me an accurate reading for testing power supply readings to get an idea whether or not the thing is a piece or if it's going to blow, if it will truly give enough juice on the various rails to power my equipment, etc.. Something that's also easy to use for a novice such as myself, who is also not sure as to what you mean by form factor. While I'm into computers, I haven't delved into the deeper part of it such as doing things with a multimeter.
Super KW said:Get my new mobo and my +12v reading is 12.34plus my GPU's are much cooler now
jonnyGURU said:You're happier with .34 over than you are with .22 under?
No offense, but you are clueless.
How are you measuring the temperatures?Super KW said:my gpu temp was idle 55 now 48
my cpu temp was idle 38 now 28
my MB temp was idle 54 now 48
