Which upgrade first: CPU or video card?
Rehevkor
I'm looking at a full upgrade to my system, one piece at a time. I intend to get an AM2 motherboard (probably the Gigabyte GA-M61P-S3) and an X2 5600 (2.8ghz). I'm also looking at either a BFG 8800 GTS or GTX, depending on my financial situation when I decide to buy.
Given my current specs, which would benefit me more right now: a faster CPU, or a better video card?
Sounds reasonable. By the way, is there any word on release dates for AMD's quad core chips? I might just get the video card now and wait for those before I upgrade the rest. Assuming they aren't crazy expensive at launch, anyway.
Edit: The desktop quads, anyway. I know the server quad cores should be coming out soon, but I haven't heard much about the "Phenom" desktop chips.
Depends on your goal...
Faster overall computing: New Intel Core2 chip, eVGA 680i SLI A1, and some DDR2 800
Faster gamging: New 8800GTX or Ultra (for your 24" monitor)
It's all gaming for me. You think I need a GTX for 1920x1200? The Ultra would be nice, but I would like to keep both of my kidneys.
You will want a GTX or Ultra for 1920x1200. However, with G92s supposedly a few months away, I say get the mobo and proc now, and the video card later.
I also strongly suggest going Intel Core 2 unless you building on a limited budget. For mid or high end gaming, Core 2 is quite superior to AM2, and there is little to suggest that this arrangement will change next year with Penryn vs. Phenom.
Consider the X6000 v. the E6850. Both run at 3ghz, but the X6000 is more in the league of the older E6600 running at 2.4ghz rather than the E6850 in terms of performance matching. That's a 600mhz difference for two dual core procs running at the same clock speed. This also doesn't account for the Core 2's superior OC capability. An E6750 or E6850 can OC to 4ghz easily with a good air cooler.
Mark.
I'll consider going Intel, but the prices are discouraging. If I do, it'll be some time down the road, so I would likely get the video card first anyway. I can't afford to pay a premium for an Intel board and a C2D and drop $511 on a video card at the same time. I think I'll get the card now and wait a bit on the CPU upgrade.
Thanks for the info folks. :)
