Which temp reading is correct??
chzxmnky
Hellooooo, I have a BFG 6800GT AGP with stock cooling. It's the one with the blue board, and two blue LED fans:
I have Everest to read my temperatures, but the temperatures seem to be reading different than in my nVidia settings. Heres a screencap:
As you can see, the temps are 10c difference, and they change the same, and are always 10c away from each other. Strangely, though, my ambient temperatures are the same on both. Anyone know why it's doing this, or which one is accurate? Thanks!
sorry i cant help you, does it show ambient when you download a driver? or did you have to do something special? like coolbits?
It's always showed my ambient temps, before and after I installed coolbits.
I would say the temperature reading from the Nvidia Menu is more accurate, to make sure use Riva tuner.
I have the exact same thing on my system, Everest shows 10C less then nvidia.
