Hi,
a while ago i was recommended to get a radeon 5770 to go along with:
AMD Phenom II X6 1055T Thuban 2.8GHz 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor HDT55TFBGRBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103851&cm_re=x61055t-_-19-103-851-_-Product
GIGABYTE GA-880GA-UD3H AM3 AMD 880G HDMI SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128444&cm_re=ga_880-_-13-128-444-_-Product
for the purpose of gaming (starcraft 2 primarily), but when i typed in radeon 5770 into the newegg.com search bar, it turns out that there is more than one radeon 5770. So can someone help me figure out which one it is or if you know of a better video card that is compatible with these pieces for about $180-$200.
I may be asking for a lot but I also have another question and that is i was also recommended a corsair 750w power supply to power these things, but it turns out there are three of these on newegg, maybe you can help figure out which one i should take?
