Which Lian-Li?
jedolley
I'm looking into getting a mid-tower case and figured I'd take a look at Lian-Li. Everyone seems to love them and claim their quality is top-notch. Previously, I felt that some of their designs weren't up with the times (lack of tool-less design, 80mm Fans), but recently found two models I actually like.
PC K60B
http://www.lian-li.com/product/product06.php?pr_index=10&cl_index=1&sc_index=1&ss_index=4&type=a
PC G7B
http://www.lian-li.com/product/product06.php?pr_index=11&cl_index=1&sc_index=1&ss_index=4&type=b
Unfortunately, I've had a difficult time finding these for sale anywhere. Does anyone have any experiences with these or similar Lian-Li cases? Does anyone have a reccomendation where I can find them for sale?
Another case I am considering (non-Lian Li) is the Gigabyte Poseidon http://www.newegg.com/Product/Product.aspx?Item=N82E16811233006
Thanks,
JD
I have the PC7 Plus II, and love it.
I also like the PC-A16 a lot.
Performance-pcs.com is generally a good place to buy Lian-Li, but they don't seem to have the models you listed.
DE
The p7 or the pc60 are pretty much the same builds and much more readily available. About the only difference is which way the drive cage faces. The new PC-A08 also should fit the bill, although it doesn't have an external 3 1/2". You might try them.
peace,
Aielman
frozencpu.com has a lot of lan-li, however not the exact ones you are referring to. there is a case..the pc-g70b on there very similar to the pc-g7b however from the quick look i took the difference is that there is a spot for a 2nd psu...which i conjure you don't really want from your other choices....
DE
I ditto that statement. I have one of those cases too for my wifes computer. Its just like the G7B, except the fan goes in the window, instead of attached to the case.... and in the window is better, becuase its blowing in cooler air from outside the case.
I highly reccommend it.
The G70 is a full tower...and it's pretty big. He's looking for a mid.
I like the PC-G7B, very nice.
Just remember to buy a box of latex gloves, so you don't get fingerprints on them. I've had 2 Lian-Li's, a black and a silver, they stain very easily with grease. I don't have moist hands either.
Does anyone know where I can buy a PC-G7B? I have seen them for sale in several european on-line stores, but none here in the states.
as far as i know, not available in the US. Ive checked like the 7-8 top retailers in the US that sell LL, none have it.
