I got a question for you guys, because I can't decide. Which LCD should I get? and do you suggest USB or Serial LCD's
This is what it will look like without the backlight
Now this is the decision part, what color backlight should I get?
The both are about the same price and both come is serial and USB
I intend to do this with it
Thanks go to Rezistor
I'll be putting it on the door of this case
I was thinking the blue one because of my blue case, but then I thought that it might get drowned out in blue, and not be noticeable. I'm not sure how the yellow would look either, so any input you have would be nice. Also I was going to get a serial one because I don't have anymore USB's, but I can always get a hub if USB ones are better in some way.
