Which case is better?
Saint
http://www.newegg.com/app/ViewProductDesc.asp?description=11-119-035&depa=1
http://www.newegg.com/app/ViewProductDesc.asp?description=11-129-140&depa=1
I am planning on putting some high end componets into my case and will need good cooling. But I dont want alot of noise. I hear steel is better for noise and alluminum is better for cooling. I like both these cases but cant decide on which one to get. The pretorian doesnt have a power supply with it and Antec one does. But I like the pretorians front ports like audio. What do you guys think
The Praetorian without a doubt. Its way better quality and you can always add a better PSU to it than the Antec SmartPower that it comes with, like an Antec TruePower or an Enermax.
i love the 120mm fans on the BQE (what i have) but i am obsessed with things being quiet as the computer is in my room.
The Praetorian hands down. My friend has it and I love it so much that I am getting one. His has not problems with noise, really quiet and he has like 4 case fans...As for the power supply issue, you are probably better off buying a better quality one seperatley...
