which card is better...
commissioneranthony
Sapphire HD 4650 512mb gddr2
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102829
XFX 9500gt 512 mb gddr2
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150319
XFX 9500gt 1gb gddr2
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150322
I can't seem to find which of these cards beats out the other. there are only reviews of the ddr3 models of these cards, but these use gddr 2 and are low profile. Anyone know where I can find a legitimate comparison of these cards or any personal opinions? I think the HD 4650 trumps the 9500gt, but I don't have much backing evidence. thanks.
4640 is better if its ddr3 but, what are you looking for from this video card? htpc? (since you want a low profile) imo the 4650 has better decoding/encoding options then the 9500gt both but offer hardware accelerated h.264 decoding (if you have a player that supports it)
