EXreaction
- Jun 25, 2005
I am not really sure what to do here, I really would like to spend as little as possible on this, but the system must support optical input.
So far I've only seen these two that fill the space:
Logitech Z-5500
ONKYO HT-S3100
I can get either of these for about $225.
I do not like the way the Onkyo speakers look, they look pretty cheap. Also I am not sure what the best method of connecting my desktop to that would be. The onboard doesn't have any digital sound outputs. I *might* keep using my Audigy 2 ZS card for that, though part of the reason I want a new speaker setup is so I can stop using that card (the drivers suck and I am using the optical input from the live drive from my 360, with the crappy drivers sound will cut out once in a while and I'll have to restart to get it working again).
I am leaning towards the Logitech because of the space I'd save, the connections would be easier, and the speakers look higher quality. If anything else is possible for around or under that price range I would love to see it, but I can't find much if anything.
Logitech Z-5500
ONKYO HT-S3100
