BoK said:225 fsb on air, it goes higher but not stable. The prices coming down on Intel chips makes me wanna try my hand with a 2.4c.
RandysWay said:3.3 ghz. Can't get much higher. This damn thing is limited..
Ether said:What exactly does 30 Cap mean and how do you know if you have it or not (I know I don't...I have a Northwood B, but I would still like to know)?
Ether said:Wow, I never thought to equate Cap with capacitator..../dumbass
Are these the rumored Gallatins with the disabled cache (from defects or something)?
TheLastV8 said:My 3.0C is doing 235 FSB at standard voltage, higher speeds wont work think my noname MDT ram is limiting it. Im a little concerned about the amount of heat it puts out according to my p4c800e, temps going well over 60°C and 50°C in idle. But its rockstable and i will add some new holes in my case soon maybe some new air will help .
