but to answer your question, you will need a dhcp server of some sort to share you internet connnection with all the devices on your network.
Unless your ISP gives you 3 IP's then you will need a router.
Not really true, some switches (not bare-bone switches I guess) do have NAT.
You just need something to act as a NAT device, though.
I would suggest just getting a Linksys WRT54G. Works pretty good right out of the box, although you may need to setup some port forwarding (and disable the wireless if you don't use it).
no.can i just junk the damn router and use a switch? will my 360 and 2 pcs work with that without hassel?
Just to add on here, because it hasn't been laid out clear -
If a switch does NAT, it's a layer three switch, which makes it technically a router.
Here's the rundown for the OP - I assume you're wanting to share internet between these three devices - like someone else mentioned, get in touch with your internet provider's tech support and ask them how many if you can get three DHCP addresses and if there's an extra cost associated with it. If there is a cost, and you'd rather not pay it, you'll need to get a router as the poster above me indicated. They really aren't that hard to set up.
